09-04-2024 06:38 PM
I just set up an account. Got message “you have set up a PIN number” . The only problem is I never set one up. Now what
09-04-2024 06:46 PM
Worked great, thanks so much
09-04-2024 06:43 PM
You can update/set your account PIN using this direct link on browser:
09-04-2024 06:41 PM - edited 09-04-2024 06:44 PM
@Paddy2 You most likely don’t even have option to change PIN number on newly created accounts . It used to be we had to set one up on activation on older accounts . But this step is skipped now on activation . But you can check your account profile page for PIN option and change it to whatever 4digit PIN you want . Or you simply do t have the option and nothing to really worry about . It’s good thou for using *611 and account confirmation when you need support
pic of where to see it @Paddy2 if you even have the option on new account
