06-28-2020 09:56 PM - edited 01-05-2022 12:20 PM
So my renewal is on July 2nd. I have 4 dollars of funds remaining. I went and made a payment to cover the amount due. I never got any confirmation that the payment was successful. So I tried again but got a message saying that I already have enough funds in my account to cover next month’s renewal. But my available funds still show 4 dollars. Usually when I do this, the funds get updated right away. Thoughts?
06-29-2020 02:06 PM
I decided to do another payment of a specific amount. This time it went through and the Funds Balance has been updated. I'll continue to monitor if those transactions last night get posted.
06-29-2020 10:03 AM
@mobileguy I definately would say that nothing was processed.
I would try payi g $1 and see if that goes through.
06-29-2020 09:01 AM - edited 06-29-2020 09:01 AM
I checked my CC account this morning and there are no pending transactions for Public Mobile from what happened last night. I'll check one more time tomorrow. If I don't see anything, then I'll write it off as a glitch. Thanks.
06-29-2020 08:58 AM
@mimmo , the self-serve says my next payment due is July 2nd. My last payment history shows the payment from last month. No indication of any transactions after that.
06-29-2020 08:56 AM
@gpixel , thanks. I used to do that but last month I hit the wrong option and topped up only enough to cover the amount due. It worked nicely so I thought I would do the same this month too.
06-29-2020 12:50 AM
@mobileguy If your card wasn't charged. try choosing "other(enter the desired amount)" and manually inputting the funds you need, instead of "amount due".
06-28-2020 11:23 PM
@mobileguy I don't see it mentioned but what does yourselfserve transaction history show?
Iirc if your cc is on file you should also be able to add funds via 611.
06-28-2020 10:26 PM
@mobileguy wrote:Thanks everyone for your help so far. Just called *611 and it says I have a balance of 4 dollars. I'll check my CC tomorrow and see if a payment went through. If it did, then I guess I'll need to call up a Moderator?
You can call the number on the back of the card and use whatever automated system they have. Or log in to the account. There ought to be at least a pending transaction shown.
06-28-2020 10:24 PM
Sounds like a glitch. You can check again tomorrow.
If you paid and the balance doesn't show it, you can contact moderators. Click on the green question mark at bottom right to get started. Enter your question into SIMon. Follow/invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
06-28-2020 10:21 PM
06-28-2020 10:16 PM
Maybe try a different browser or incognito/private mode and have a look again.
06-28-2020 10:16 PM
@hairbag1 , yes, tried that multiple times and no change. Funds still show 4 dollars.
06-28-2020 10:15 PM
@mobileguy wrote:@hairbag1 , That's what I usually do and that’s what I did this time too. Just that mu funds did not get updated so I'm not sure if the payment did make it or not.
Log out and then log back in...see if the amount in Available Funds has been updated.
06-28-2020 10:13 PM - edited 06-28-2020 10:15 PM
@hairbag1 , That's what I usually do and that’s what I did this time too. Just that my funds did not get updated so I'm not sure if the payment did make it or not.
06-28-2020 10:11 PM
@Anonymous , my renewal date still shows July 2nd. I pay with my CC.
06-28-2020 10:11 PM
@mobileguy wrote:@RossN , I only have one account. The payment must have gone through because when I tried a second time, I got a message saying that I already have enough funds in my account to cover the renewal.
@mobileguy yea I understand but for piece of mind I would check my cc
06-28-2020 10:09 PM
06-28-2020 10:08 PM
@mobileguy wrote:Not sure if I want to add more funds right now. The system appears to believe that I have enough to cover my next payment but my funds show otherwise.
You should be able to deposit any amount you want into Available Funds. Please double check on when your renewal date is and let us know.
06-28-2020 10:05 PM - edited 06-28-2020 10:07 PM
@mobileguy that is indeed odd do you have a couple of accounts possibly paying the wrong one? or maybe the payment just didn't go through? if you paid with a cc can you check to see if a payment went through?
06-28-2020 10:05 PM
06-28-2020 10:04 PM
@mobileguy wrote:So my renewal is on July 2nd. I have 4 dollars of funds remaining. I went and made a payment to cover the amount due. I never got any confirmation that the payment was successful. So I tried again but got a message saying that I already have enough funds in my account to cover next month’s renewal. But my available funds still show 4 dollars. Usually when I do this, the funds get updated right away. Thoughts?
What's your renewal date now?
If you used a payment card, does it show a charge?
06-28-2020 10:02 PM
I just add $$ to my Available Funds...then when the renewal happens, I'm covered.
06-28-2020 10:02 PM
@mobileguy Go to your self-service account and select a manual payment with "other" amount. You can transfer any amount you want no matter how much you have in available funds.
06-28-2020 10:00 PM
@RossN , I dialed the number and it says I have a balance of 4 dollars. This is not looking good.
06-28-2020 09:57 PM
@mobileguy hi dial*611 see what it says😁
