Forward a specific number to another number
rishfilet
Hello,
I have an interesting case whereby my condo won't allow two numbers to be registered in our directory. I want to be able to forward to buzzer call to another number (my roomate) if i am unreachable. I only want this one phone number being received to be forwarded to his number. Is there a way to do this with Public forwarding on android? Specifically forward to ONE specific phone number from ONE phone number being received?
Thanks
CountyDownIeUk
Here are your transfer options from a mobile phone.
Yummy
I do not think you can selectively forward numbers to particular one.
Something like this will not work:
if call is from xxx forward to yyy
everything else forward to zzz
@rishfilet   Obviously you don't want all your calls got routed to your friend when you are unreachable
Suggestion for you is to get a VoIP phone number.  e.g. Fongo.  And setup forwarding if unavailable that way
In this case, your app will ring, and will forward to your friend if unavailable.
