10-25-2016 04:47 PM - edited 01-04-2022 03:43 PM
Hi All,
Wondering if others have this problem as well:
Often when I respond to a post, it will say that the posting is succesful. If I leave the screen and come back to it, my response does not show and I need to reply again. Usually the second time I reply it will go through.
There have been cases where I reply, and when I check back a couple days later, it shows that I never posted :S
10-25-2016 08:25 PM
You should notice if using the desktop browser anyway, when you click the post button, a page reload occurs, and you're taken back to the post you hit reply on. At the top or bottom of said post ( I don't remember which at this time) there will be a Sucess message with a link to your post in the thread.
*Sometimes*, another post in the thread maybe be moved to create a new thread. I am not sure, but I think this action may drag with it, any posted replies to said post.
i think this happened to me once. I know today, a post I was replying to was moved before I completed, and as a result, I was red text errored as the post was no longer available. I found the same post as a new thread, and then responded as I wanted to previously.
i hope this helps!
10-25-2016 05:24 PM
Oh, is it a glitch? Happened to me too a few minutes ago....
I thought my post got deleted by mods as I was a tiny little off topic.
10-25-2016 04:54 PM
I had that issue about two weeks ago. None of my messages would post. I ended up logging out, closing and opening my browser and logging in again, and it resolved the issue.
10-25-2016 04:52 PM - edited 10-25-2016 04:52 PM
Nope, never happened to me. Sometimes it gives me red highlight error but i hit post again it goes through.
May be try clearing your browsers cookies and caches.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
