Forgot to put in promotion code when activate Sim Card
bamboogarden
Hi, I just realized i forgot to put in the 2GB promotion code when activating my SIM card today. Is there a way to add it in? Thanks!
2 REPLIES 2
bamboogarden
Thanks a lot for the prompt reply and detail instruction! Cheers.
HI @bamboogarden   PM CS Agent likely able to add it back for you if you meet all the requirements on the promotion.  Please open a ticket with them at  : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
