08-22-2021 03:47 PM - edited 01-06-2022 03:12 AM
Dear Sir/Madam,
I forgot to renew my plan before the 90 day mark a couple of days ago and I was wondering if there was any way that I could keep my number.
08-22-2021 06:30 PM
@Yummy They know that already, your too late. lol
08-22-2021 06:21 PM
@Anonymous wrote:go to your account and make a payment
and then will be back to working...
This is not correct advice.
As soon as account goes beyond 90 days of no payment, account is closed.
08-22-2021 04:16 PM
@Anonymous wrote:@Anonymous @computergeek541
but when i do reply to that post has no say 90 days ok and maybe the do Edit Message, and i'm not see it the do Edit...
@Anonymous : As we've discussed, there's no requirement to say that one has done an edit. For us regulars here it's just common practice/courtesy. Pretty much the same with any forum. Non-regulars won't care about those matters. I highly doubt they edited their post.
08-22-2021 04:13 PM
thank you for both,
08-22-2021 04:12 PM
08-22-2021 04:11 PM
@Anonymous : Google Translate. See my edit above.
08-22-2021 04:11 PM - edited 08-22-2021 04:12 PM
@hd4808 wrote:It’s been 91 days, does that make a difference and help in any way?
To see if your account is closed try logging into self service in case you miscounted. If you cannot it has been closed.
08-22-2021 04:10 PM - edited 08-22-2021 04:11 PM
08-22-2021 04:09 PM
@Anonymous wrote:but at OP that i see at for couple days not 90 days i don't how maybe the do Edit Message the OP.
The OP went pas the 90 days by a couple of days. Unfortunately, the account cannot be reopened and has been closed. Service cannot be simply resumed by making a payment. As to whether or not the phone number can be recoevered, that isn't guaranteed either.
08-22-2021 04:09 PM
08-22-2021 04:08 PM - edited 08-22-2021 04:10 PM
@Anonymous : The OP said they went past the 90 days by a few days. The account is closed. There's nothing they can do but beg and plead for goodwill from the CSA's. Roll out your cut and paste contact the mods if you like.
Edit: run the OP through Google Translate and you might pick up the syntax of the sentence used. He said forgot before.
08-22-2021 04:06 PM - edited 08-22-2021 04:07 PM
08-22-2021 04:06 PM - edited 08-22-2021 04:08 PM
@hd4808 wrote:Dear Sir/Madam,
If it has been more than 90 days since your renewal date your account would have been closed and number gone. You will need to buy a new SIM card and go through the activation process to open a new account with a new number.
08-22-2021 04:05 PM
Missed a payment? After your plan expires, all you need to do is top-up your balance to keep the current plan going. You have up to 90 days to make a payment and, after doing so, your payment cycle will restart and your service will resume.After 90 days of non-payment, your account will be permanently deactivated, which means you will:
08-22-2021 04:03 PM
As the account has already been closed, this is no longer an option.
08-22-2021 03:59 PM - edited 08-22-2021 06:28 PM
08-22-2021 03:49 PM - edited 08-22-2021 03:50 PM
@hd4808 very likely not..
but i suggest you to open a ticket with PM Customer Support Agent now, earlier the better, and hope they can do something about it
To open a ticket with PM, click on the Bubble or directly at : https://publicmobile.ca/chatbot
Enter your question in SIMon. Follow the prompts until you reach the Contact Us button,
