Forgot login
Maggyann
Can't login to update payment info....firgot email and or password used
1 ACCEPTED SOLUTION
Accepted Solutions
@Maggyann start with the Forgot Password link there, if that doesn't help, open ticket with PM support and they will sort that out for you
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
MrSpock
@Maggyann hi if you forgot password  and email  you can contact  a cs agent explain your problem  Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
Maggyann
Ty....ill try that
RossN
@Maggyann
hi contact a cs agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type  request email and new password
2. alternatively you can private message them here
