Forget password
John28
I forgot my password and the security question to reset my password
HI @John28
if you already tried to reset password using the link there, then you have to reach out to CS Agent for help
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
Meow
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
@John28  - if you cannot reset your password ask CSA for help.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
