06-24-2022 07:15 PM
I ordered a SIM card and I am trying to put it into am IPhone 10. It seems to be a bit too big. Just wondering if i can take this SIM card back for a smaller one?
Service
06-24-2022 08:25 PM
06-24-2022 07:31 PM
Look closely at your SIM. It should be 3-in-one type where you can pop out size you need.
06-24-2022 07:22 PM - edited 06-24-2022 07:23 PM
@AlishaMcG hi the sim breaks apart you can see where the three sizes just carefully break it down your size is most likely the smallest
