11-29-2024 07:35 PM
I was setting up my new account/sim. I got my old number ported over but my new sim won't work and when I try to login to my account I get a forbidden A! message on my phone and PC
11-30-2024 06:56 AM
@Josh444444444 Probably best to contact customer service. Since you can't log in, send a private message directly to support agents using the link below. The chat icon bottom right of this page is the usual way to open a ticket but that likely won't work for you. Send a private message using this pre-addressed link and watch for an agent to reply at the envelope icon top right of this page or, if no envelope, tap your avatar and select Messages.
11-29-2024 09:55 PM
Yes I've restarted Multiple times. Its a physical sim. My phone recognizes it as a Public Mobile Sim. When I try to login to my account online I get a message that says Forbidden A1 and wont login. If I try in the app it just closes. Tried calling *611 and it has a recording that my subscription was my service was deactivated due to no payment. If I try to make a call it says I don't have an active plan
11-29-2024 09:49 PM
Yes, its a physical sim and ive restarted multiple times
11-29-2024 07:42 PM
@Josh444444444 Have you restarted the phone after inserting the Public Mobile sim (or is it esim?).
