Forbidden A1
AYardie
can't log into the self serve with this "Forbidden A1" message.   So frustrating!
1 REPLY 1
hi @AYardie did you try using the app to login? or use Incognito/private/secret mode on your browser?
if that does not help, please check with PM agent for help.   please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
