10-08-2015 09:24 PM - edited 01-04-2022 02:04 PM
10-09-2015 02:34 PM
@margosince81 Check here as well: Get any Roger or Fido iphone unlocked for $13 to work on PM
Also, if you wish to keep your Fido phone number when you join PM you must be sure to keep your account active until the transfer has completed. You will be able to use your Fido SIM card until that is completed.
10-09-2015 09:24 AM
You definitely need to unlock your phone first before you can use PM service. There are refutable site which will unlock your phone for cheaper.
10-08-2015 10:37 PM
10-08-2015 10:17 PM
Hi @margosince81, you need to get your iphone unlocked first. You may refer to redflagdeals for some suggested site for unlocking on sale recently for Rogers/Fido phone. The offcial unlock price from Fido is $50, and you need to be an active customer with Fido. Hope that your issue will be resolved soon.
10-08-2015 09:48 PM
You will have to get your phone unlocked first.
Only Telus and Koodo phones work on Public Mobile without unlocking.
10-08-2015 09:40 PM
10-08-2015 09:32 PM
Hey @margosince81, can you confirm that your iphone 6 is unlocked?
