05-24-2019 11:37 AM - edited 01-05-2022 05:03 AM
Can I purchase extra talk time minutes for a 30 day time period only?
06-02-2019 08:03 PM - edited 06-02-2019 08:06 PM
@Tiptopssss wrote:Yes, look around In the add on section
All good of you to jump in participating in the community but notice the green bar and the green check mark. That indicates that the original poster (OP) has selected a reply to be the answer to the question.
Also...your answer is incorrect to that OP. There is no 30 day add-on.
06-02-2019 07:58 PM
06-01-2019 01:07 PM
At this moment (Saturday) you can purchase 500 min Canada wide addon for $5.00 plus tax. The adddon carries over until used which would be after your plan minutes are used that month. I have no idea how long this 500 min addon special will last so... Cheers
05-31-2019 06:47 AM
Yes. For our In Canada Add-Ons, any unused data or minutes will roll over to your next cycle.
05-31-2019 06:43 AM
Yes you can. And the Add-On minutes won't expire.
05-31-2019 06:37 AM
Can someone please confirm the following :
If I am on the $15/month plan with 100 min talk time and I use up all 100 mins, can I buy either the $8 - 200 min long disntance Canada/USA or the $15 - 400 min International long distance add-on AND USE IT FOR LOCAL CALLING ?
Thanks.
05-25-2019 08:24 AM
@BillMurray wrote:Can I purchase extra talk time minutes for a 30 day time period only?
You have 2 Calling Add-Ons to choose from:
=> $8 for 200 U.S. & Canada Long Distance minutes (4 cents per minute).
=> $15 for 400 International Long Distance minutes (3.73 cents per minute).
The Calling Add-Ons do not expire. Minutes from your plan will always be consumed before the minutes from Add-Ons.
05-24-2019 11:42 AM - edited 05-24-2019 11:43 AM
@BillMurray If you need additional minutes Public Mobile has add-ons that you can purchase. The add-ons remain on your account until used so they never expire and are a great way to use the as a backup for minutes when needed.
More info on add-ons can be found here.
Edit: You can purchase a 200 minute Canada/US add-on for $8.00.
