04-04-2025
01:48 PM
04-04-2025
03:21 PM
computergeek541
04-04-2025 02:05 PM
hi @Julio7
Telus should be able to
anyway, submit proper support ticket with PM support agent then
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
04-04-2025 02:04 PM
Yes still waiting on reply.
04-04-2025 02:03 PM
ITS what I thought. Lol
They cannot do anything
04-04-2025 01:56 PM
what did PM do to your phone number, why you cannot download anything? and you only need a text from PM, you don't really need to download anything
you can ask PM to look into it by ticket. Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
04-04-2025 01:55 PM
hi @Julio7
since Telus owns Public Mobile, you can in fact call Telus live support and explain the situation and they can simply move the phone number over without your get the porting authorization text from PM. Call Telus helpdesk first
