06-04-2023 08:17 AM
Since you can't opt out sending code every time (even said trusted device),any option to send code to email or another phone (I set an alternative number using mine, didn't work) I managed my familys multiple accounts,they are not all the time with me to get the code.very inconvenient, also I lost my community old 🆔,thx
06-04-2023 08:22 AM
@yack With the Trusted devices option that does not work, are you using app on iPhone? It works for me on Android or desktop
If you have completed the setup of EverSafe ID, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
