06-22-2026 02:06 PM
06-22-2026 02:11 PM
make sure your Public Mobile esim is set to primary in cellphone settings. Remove the old hard sim )or deactivate the the old esim).
06-22-2026 02:10 PM
send and receive calls? and send and receive texts?
you might need to ask PM support agent to help to reprovision the account and sim. You can submit ticket by direct message:
