Esim
Worris
Once I get to Europe, how do I use my esim ? Worris
fixin
@Worris - Use a eSIM like Airalo or buy a local SIM card for data. Then use VoIP like TextNow for making & receiving calls while in the Europe.
If you are on iPhone, you can always enable temp conditional call forwarding from Settings > Phone > Call forwarding, it will load up for less than a minute to talk to the carrier tower and then you can enable it and enter in your text now number. Make sure to disable PM eSIM to make a longer battery life.
@Worris
if you meant using Public mobile service in Europe, sorry, you cannot.  PM does not have roaming service there.  PM only has roaming service in US
if you meant using travel esim, you can still install your travel esim.  But remember to just disable PM esim and NOT to delete it.  Phones can have multiple esims installed
Sansan
@Worris sorry no roaming in Europe.  Public Mobile only works on Canada.  Canada-US plan or add-ons.
Brianna182
If you're talking about a public mobile esim, it won't work in Europe. If you bought an esim from another provider for your trip, it should have come with pretty clear instructions on how to set it up, they are not too complicated. But if you tell us the provider and what phone you have, I or someone else can probably help you out
