04-01-2024 12:30 PM
04-01-2024 03:05 PM
Hey,
Thank you for this. Unfortunately, I have not received the welcome email and the Iphone 13 settings does not have the "cellular" section as per the screenshot. The only available option is Settings->Mobile network and I cannot find any PM sim option there. It only has "Setup eSim" and that doesnt work without the QR code.
Is there any other way to navigate this problem?
04-01-2024 12:35 PM
What was the exact error message? Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, Please open ticket with PM support:
04-01-2024 12:33 PM
HI @geet
do you have the Pm esim installed? check the Settings -> Cellular screen, is it there?
if it is there, remove your old carrier sim card or disable your old carrier esim. Then make sure PM esim has "Turn on this line" turned on. Reboot the phone and test
