3 hours ago
- last edited
3 hours ago
computergeek541
Hello All,
So while trying to sign up I've got the "Subscription not Activated" error and it said to contact support. I sent a message to CS and through the chat they were apologetic but ultimately said they can do nothing except offer to get me a physical SIM so they can set it up on their end or try signing up with a new email.
HOW IS THIS ACCEPTABLE? my CC has already been charged and I really see those as non-solutions. Was the CS agent correct these are the only options? Just wondering if anyone in the community might have a better answer.
Lesley
3 hours ago
3 hours ago
Ok, if they didn't suggest, then you can ask. If not, it's quicker and cheaper if you use Amazon.
3 hours ago
@Lesley_0330 ask the agent.. Sometime they will help you to get a new one using the app
but what phone do you have??
3 hours ago - last edited 3 hours ago
3 hours ago
@Lesley_0330 get help from PM support first. In many cases, support can send you an eSIM QR code and make it works
3 hours ago
@Lesley_0330 I have seen many post where esim did not work and they had to ultimately get a physical SIM in the end.
The esim was free. Are they not offering to send you the physical SIM for free?
3 hours ago
I was intending on using an eSIM but unfortunately didn't even get as far as installing the eSIM before the app came up with that error. 3rd gen IPhone SE.
3 hours ago
@Lesley_0330 did you try setting up an eSIM? if so, what phone are you using?
