12-07-2023 04:27 PM
No data transfer. When I call, it says that you need to select a tariff plan. The money has been debited from the card ($56). SMS from number 988-3838 coming.The account was activated 3 hours ago. I don’t understand anything. Help pls!
12-07-2023 04:52 PM
No go if you activate online. PM removed this feature so you need the app to activate the SIM.
12-07-2023 04:36 PM
@DenisKh Try the app . It should make the difference , can’t activate on the website no more since the PM app came out . And if same use the link I provided in first reply to contact support to help
12-07-2023 04:33 PM
I used the website to activate.
12-07-2023 04:29 PM - edited 12-07-2023 04:30 PM
@DenisKh and you were using the app to activate ? Not website all activations need the app . Heres a direct link to support to investigate
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
