03-27-2021 07:44 PM - edited 01-06-2022 01:35 AM
I made the payment and selected my phone number and the payment was taken but I received a Error code # 812.
I opened a ticket 2 days ago and haven't heard back.
What is that error number about?
03-28-2021 01:11 PM
@Lydiaa wrote:No services at all...
@Lydiaa did you try calling that Porting Phone number?
You can also inquire with the Moderators. If you paid you should have service if you have a compatible phone.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
03-28-2021 01:10 PM
03-28-2021 01:09 PM
Ok I'll try but am I going to have to do the whole process again? I already made a payment.
03-28-2021 01:08 PM
No can't login and the number is not in service
03-27-2021 09:07 PM - edited 03-27-2021 09:09 PM
@Lydiaa check your private message inbox. moderators have most likely responded to your ticket already. this error most likely failed to create a self serve account. if you cannot login to your self serve then you will need to ask mods to fix it for you. don't put this off as the self serve account is very important
03-27-2021 08:59 PM
The key question is, do you have active, working services?
If you do, don't worry about any error codes.
03-27-2021 07:54 PM
I think error 821 is a hardware problem with your computer.
Try using a different computer and see if the same error shows up.
03-27-2021 07:53 PM - edited 03-27-2021 07:53 PM
@Lydiaa Can you login at all?
cc @CS_Agent user haven't heard back in a couple of days.
03-27-2021 07:48 PM
Actually Error number 821
03-27-2021
07:47 PM
10-09-2023
08:32 AM
@Lydiaa wrote:I made the payment and selected my phone number and the payment was taken but I received a Error code # 812.
I opened a ticket 2 days ago and haven't heard back.What is that error number about?
@Lydiaa , If it has been 2 days since you created a ticket, and you have not heard back from any Moderator, I would send in another ticket.
Do you have ANY services?
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
