10-05-2023 08:17 PM - last edited on 10-06-2023 01:29 AM by computergeek541
Signed up for $50 Can/US plan using eSim earlier today and I can’t receive any incoming calls.
Whenever someone tries calling me, they get “error code 6ut1: The number you are calling is not in service"
However, outgoing calls work. I tried restarting my cellphone and nothing has worked so far.
I have tried looking through other posts but couldn’t find any solution
10-05-2023 08:19 PM
HI @Fishyflyer
did you port in your number? if you did, you got a text from old carrier and you replied Yes? If you ported in number, the port was not done. i will send you a number to call porting team to confirm. Please check Community inbox for the number
