How do i remove voice mail
Rhum
2 REPLIES 2
HI @Rhum
you cannot disable it completely.  But you can put Extended leave of absence recording and not let people to leave a VM
HALIMACS
You cannot, @Rhum , however you can set an extended absence in such a way as to avoid callers from leaving messages.
  • Call voicemail and log in with your PIN,
  • press 3 (manage greetings),
  • then 4 (manage extended absence greeting),
  • then 2 (record a new extended absence greeting) and record a message that indicates to your caller you are not accepting messages,
  • then press 4 to enable extended absence,
  • lastly, press 5 to disallow anyone from leaving you a message.
