10-25-2024 11:38 PM - last edited on 10-25-2024 11:46 PM by computergeek541
10-26-2024 05:20 AM
@parkay123 In addition, make sure to port out your number to the new provider a few days before your PM plan expires as the account needs to be still active for the number transfer to work. A buffer of a few days allows for possible glitches. Don't wait until renewal day.
10-25-2024 11:47 PM
@parkay123 PM is running on 30 days cycle and your plan won't ends on the same day monthly. Please login My Account and confirm your current cycle end date
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can disable the toggle "Subscribed" to disable Pre-Authorized payment instead. Once it is disabled, PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
10-25-2024 11:46 PM
@parkay123 wrote:I pay my bill on the 21st of each month. I’ve decided to go with another company. How and when can I end my service with public?
Public Mobile does not bill on the same day each month, but to discontinue service, you'll need to disable autopay from within your self serve account. After being in suspension for 90 days, your account will automatically be closed. If you port your number to another carier, that immediately closes your Public Mobile acocunt. In either case, be sure to disabled autopay first and also use the chatbot to open a ticket and ask a Public Mobile customer support agent to remove your credit card information from the account (before any number porting attempts if you end up going that route).
