06-13-2024 11:38 PM
06-13-2024 11:56 PM
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
06-13-2024 11:45 PM
@Dot123 wrote:Is there a fix? Trouble shooting ideas or just wait till fixed?
What types of errors are you encountering? Try running a web browser in incognito/privacy mode or clear the Public Mobile app storage before logging in to see if that helps.
