04-10-2023 06:11 PM
04-10-2023 06:17 PM
Please submit a ticket with PM agent for them to make the email change for you
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
04-10-2023 06:15 PM
Only PM agent can update your email.
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
