04-10-2023 05:32 PM
Hi,
Rogers pay as you go has no account #. How to transfer the phone number to Public Mobile? By entering SIM card # ?
Thank you
04-10-2023 05:35 PM
@Jsmart you can try using IMEI for porting info but it could cause errors sometimes. It is much safer to use Account number instead
04-10-2023 05:34 PM - edited 04-10-2023 05:35 PM
You'll need to know the Rogers service account number to do this. That service will also have to be active to receive the port authorization request approving the transfer from there to here.
The Rogers SIM card needs to be put back into your device, then go to the self-serve page under Profile to request porting from there to here.
It's under the Change Number function there.
