04-10-2023 06:33 PM
Hello, dear friends from the community!
Today I added funds to my account that will be used for the following two months. My question is: if I press the pre-authorized icon, the next time will it take the money directly from my funds, even if they have my credit card details there?
That's what I want, but it's just to be sure. Thank you!
04-10-2023 06:40 PM
Thanks, @hTideGnow!!!
04-10-2023 06:38 PM - edited 04-10-2023 06:40 PM
Hi @vertelop yes. The system always applies eligible rewards first, then from Available Fund. Any outstanding will then be taken from Credit card if Pre-authorized payments is enabled. So, if you have enough Available fund, the system won't try CC at all
04-10-2023 06:38 PM
Thank you, @Dunkman! 🤗
04-10-2023 06:36 PM
You are correct. Available funds will be taken out first, then your credit card will be charged next.
