09-28-2022 02:27 PM
No longer have email setup on this account have old email and no way to get into my public mobile have new email want to switch email
Community
09-28-2022 06:29 PM
another member said that exact same thing 4 hours earlier
09-28-2022 06:26 PM
So I guess it was overnight last night. The new system now requires 2FA. Once logged in then you can turn that off. As mentioned to you earlier, only support can change that email.
You could open the chatbot and say yes that you're a customer and then sign in and then click manage my account and check some things like which plan it thinks you're on. Maybe you got the old autopay bug of changing plan to a higher cost and it failed. If it shows the new plan then you can use the registered payment card and add more money and maybe it will reactivate.
09-28-2022 06:24 PM - edited 09-28-2022 06:25 PM
@Allanbarker Yes, Autopay could fail, eith a PM system issue or your CC
Try to get back into My Account first. Open ticket with PM support as advised on my post earlier.
You can also try to pay manually by using *611 if you know your 4 digits PIN..
09-28-2022 06:20 PM
Payment was supposed to come out today didn't come out I have auto and coming out for 4 years when they switched the public mobile apps everything changed been trying to get into my account wants to send me notification to make sure it's me but it's sending to my old email which I no longer have trying to switch over to my new email doesn't seem possible
09-28-2022 06:06 PM
Did you contact support? Did they say they changed it?
For the plan, did you set it up to change at your next renewal? Does your account say today as the end date? Has a payment for anything happened yet?
You can still login with your old email and you can verify via SMS. Unless you're suspended.
09-28-2022 06:03 PM
Changed my plan a couple of weeks ago went to the 20 gigs for more money payment was supposed to come out today but payment wasn't updated either is my email it's an old email that I had when I signed up for public mobile 4 years ago I no longer have that email I have a new one trying to switch over to my new one doesn't seem possible
09-28-2022 03:34 PM
Are you a current customer @Allanbarker ?
If you ported out a public mobile number to another provider or an account was closed due to 90 days of nonpayment, then you cannot access My Account/Self Serve (once known as). So you'd have to activate a new sim card for a new account with public.
Otherwise, if you are a current customer, see other posts.
09-28-2022 02:46 PM
You can still get into your account with your old email address but have the 2FA code sent by text to your phone.
To have the email change on your account you need to contact a CS_Agent by the hyperlink as noted by @softech .
09-28-2022 02:30 PM
@Allanbarker you will need PM support's help to change the email address
To request a change on the email, please open ticket with PM support using "Forgot password" type of ticket
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
