Call forwarding number
Hus
Hi I was using the application “Fongo” (it’s an app that allowed me to make calls ONLY when I was on wifi. It worked perfectly but I couldn’t send messages so I got public Mobil.
my question is …If I call forward my Fongo number to my new Public Mobil number, do I use any data?
second question is : does the unlimited incoming calls still apply? Even though it’s coming from Fongo (but my PM number will ring)
thank you in advance
CountyDownIeUk
Here is your Fongo Call Forward Process
I  used to call forward our voip.ms account. Never a charge on PM. But was a dual charge at voip.ms. But the link above says FREE for you, for Canadian numbers.
CountyDownIeUk
NO
YES it will counted as an inbound call.
CountyDownIeUk
Try this from your Fongo number.
Remember
@Hus
no matter for call forwarding or incoming calls your plan has unlimited incoming,
no data used for call forwarding,
https://support.fongo.com/hc/en-us/articles/212434466-Call-Forwarding-on-Fongo-Mobile
dust2dust
If Fongo offers call forwarding then yes you can do that. No it won't use your cell data. Fongo ought to have worked on cell data though. Not just wifi. It's just an internet app. They have a paid option for texting too.
@Hus
1. no data use.. thee calls got forwarded to PM from Fongo as a voice call
2.  yes still treated as incoming calls and you are ok since you have unlimited incoming
