Email
Maddy7979
I want to update my email id
10 REPLIES 10
XAFDX
They didn’t say anything but I would avoid changing the email address for months or until you see people having success. It seems like the new system has a lot of bugs and this last week was a nightmare.
@XAFDX wrote:
UPDATE: FIXED - the only way to fix it was to change the email back to what it was before and have the agent assign the temporary password “Public345” (you should change this after you get back into your account).
@XAFDX   Thanks for following up.  And did PM support promise that you can change it back to the "new" email after so many days?
XAFDX
If the system has some left over similarity to the previous system, then they need to change the email address in two places in their system. There was an account email and then a login email.
XAFDX
I was able to access the new portal previously, then changed my email with an agent, and since then cannot log in/they don’t know how to fix it.
@XAFDX wrote:
Don’t do it! I had them change mine and now I cannot access my account at all!
@XAFDX   So, you were able to access the new My Account portal before you change your email address?
or you never able to anyway?   I wonder if changing the email address has any part to your issue for unable to login
XAFDX
Timer
@Maddy7979
go to your private messag type  CS_Agente
to get support team,
Yummy
Only agent can do that for you.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
dust2dust
Wouldn't we all. You'll need to contact the support people to get it changed. Start with the chatbot link bottom of this page.
