Email address used for registration not able to be used for password recovery
Gscheppink
Currently have a problem trying to recover a password for an account.  Used email+1234@gmail.com for email address.  Unable to enter the + character for email address recovery.  Anybody have any tips?
Gscheppink
I would. If I could login.
Problem is I have 7 accounts setup the same way.....
I totally agree because I have used Gmail alias in am account.  I have asked about getting this problem fixed.  I will ask again.  In any event don't expect a quick turnaround.  Change your email association in the account, I did.
Camera4617
Then Public Mobile should fix that. If they let you register with '+' in email, then they should let you reset password too. (this might never happen nor will help OP in this case probably)..
@HALIMACS wrote:
@Gscheppink
Can you copy/paste the email address from another application or document
When doing that, the Self Serve page deletes the plus signs.
HALIMACS
@Gscheppink
To my knowledge, the password reset instruction e-mail cannot be esnt to Gmail alias addresses.  You'r egoing to need to as a customer support agent for help.  Please open a ticket using the chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
