06-20-2019 01:29 PM - edited 01-05-2022 05:28 AM
I already used up my data. Is it possible to renew ealier than my cycle? Thank you.
Joining Public
06-20-2019 01:46 PM
@Scion47 wrote:How can I set up the new plan to be active right away instead of waiting until my renewal date? Thanks!
Be aware that you will loose what is left in your current plan with a changing plan now.
06-20-2019 01:45 PM
Here....
06-20-2019 01:42 PM
06-20-2019 01:32 PM
Thank you. I'll just try to get another plan.
06-20-2019 01:31 PM - edited 06-20-2019 01:33 PM
@Scion47 wrote:I already used up my data. Is it possible to renew ealier than my cycle? Thank you.
Yes you can but if you want the same plan you will need the moderator and it can take up to 2 days....or you can buy an add-on and it will stay in your account until you used it all. 10$ for 200Mb or 30$ for 1 go or you can choose another plan now...
