Usage History
Dusty3
How do I read my usage history. My data seems to be being used during the early morning hours when my phone is not being used. Is using up my data rather quickly.
2 REPLIES 2
@Dusty3
PM does not update the data usage constantly.  In fact, it only update it twice a day.
So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry.  The early morning usage  you see on the Usage log does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
umnikke8
Data is reported in batches, twice a day usually.
