ESIM
03-01-2023 03:04 PM
Is there a plan to support Esims?
I unfortunately work remotely with no cell signal and fast wifi so I'll have to leave this service otherwise.
Service
03-01-2023 04:24 PM
No eSim in the near future. Public mobile is working on VoLTE, which should improve voice quality. Public mobile belongs to Telus./ Bell Network. Depending on where you work, maybe Rogers network may be better for your purposes. As mentioned, eSIM should not affect cell signal or data speeds.
Here is a site for cellphone tower map:
03-01-2023 03:13 PM
@tony15 No eSIM support
But eSIM would not solve the issue about no cell signal or fast wifi / fast data. eSIM support is just instead of using sim cad, it uses eSim , no difference to the service
Which area you don't have cell signal? city and province?
03-01-2023 03:05 PM
@tony15 No not at this time no support for esim with public mobile
