ESIM install failed
Maddy066
It keeps getting fail in the app and I haven't received QR code in email to install it manually.
Maddy066
eventually i ended up getting physical sim card which cancel out the whole purpose of the so called online sim purchase
CSA_PM
Customer Support Agent
Thank you for bringing this to our attention! The customer was already in a private conversation with one of our agents when the post was escalated. The agent will continue assisting them directly.
hi @Maddy066
check Sim Manager or Settings->Cellular has the Public Mobile eSIM already.  Sometimes it is there, just the error message was confusing.  If it is there, enable it and Reset Network Settings
But if that does not help, ask PM agent to help.  You can submit  ticket by direct message:
slusagm
ask PM to help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
