12-28-2022
03:43 PM
12-29-2022
12:17 PM
Dunkman
06-11-2023 03:49 PM
Public Mobile now supports e-SIM - there is an FAQ doc on E-SIM. I need support though as I cannot transfer SIM card and need tech support to help.
12-28-2022 08:36 PM
12-28-2022 05:20 PM
@Chriszel08 For prices similar to public mobile with eSIM check out https://www.luckymobile.ca/shop/phones/sim-card
12-28-2022 03:45 PM
Ok thank you so much for the info ☺️
12-28-2022 03:45 PM - edited 12-28-2022 03:45 PM
HI @Chriszel08 sorry, no eSIM support for Public Mobile
12-28-2022 03:44 PM
you cannot 😞
PM does not support eSIM at this moment
you have to activate with the physical sim
