01-25-2017 03:02 PM - edited 01-05-2022 01:38 AM
If i purchased 2 gigs of data for my phone and i have already used up say 500mb,will setting my data limit 300mb cause my cell connection to not work?
01-26-2017 12:40 PM
01-25-2017 06:06 PM
You can increase or decrease the Android warning & limit levels at will though, if need be.
01-25-2017 06:05 PM
@Heavyrocker wrote:I guess what im getting at is:can you mess up the data limit setting as so it will affect me being able to connect to the internet,im not talking talking about phone connection.What haaped to me was i could not connect to the internet a few days ago but i played around with the data stting and all is good now.
Yes, if you set a data limit and exceed that limit, it will cut off your mobile data. That's literally what that setting is for (in Android, you can set a "warning" level and a "cut off" level).
01-25-2017 05:30 PM
Restrictions applied on the phone by the user has nothing to do with the carrier. These limits can be adjusted at any time by the user if the original limit is no longer deemed appropriate.
01-25-2017 05:07 PM - edited 01-25-2017 05:08 PM
@Heavyrocker wrote:If i purchased 2 gigs of data for my phone and i have already used up say 500mb,will setting my data limit 300mb cause my cell connection to not work?
if you are speaking about something such as the Android monthly data usage/set cellular data limit, and if your phone has recorded more than 300MB during the currently set billing cycle, your data will stop functioning (even if it was used up before you set up the limit). Voice services would not be affected by that setting.
01-25-2017 03:29 PM
No question is a dumb question. Setting a data limit on your phone should not affect your cellular (phone) connection. You just wouldn't get internet until you turn the limit back off.
01-25-2017 03:26 PM
01-25-2017 03:10 PM
@Heavyrocker Do you mean setting a daily limit on your phone to 300mb? If so then, no that shouldn't cause any issues cause its tracking daily.
Can you clarify please?
