Dual SIM and eSIM on the same phone with different numbers
Cujimoto
Hi.
Does PM support dual sim and eSIM with two different numbers on the same phone? I have my personal phone number via SIM but would like to set up a new business number using an eSIM on the SAME phone. Has anyone tried this? What type of phone do u have? Thank you!
hairbag1
@Cujimoto
others have that same set-up and works fine.
Cujimoto
Thx! Much appreciated
ddjiaqi
it should has no problem as long as your phone support esim. for example, I have iPhone 13, I have 1 physical sim that with pm ,and esim with freedom. it will mark as primary number, and secondary or travel number for second one.
slusagm
yes it will work, it is more if your phone will support the dual sim rather than the carrier
but yes, I have dual sim running like that too.
