3 hours ago
3 hours ago
it varies, sometimes things get all sorted within an hour, sometimes take longer
but sometimes due to higher number of ticket, could take longer
and remember, after you message them, check the community inbox here, they reply to your inbox in the community , not email
3 hours ago
How long does it usually take to get a response
3 hours ago
Thanks
3 hours ago
for whatever reason, that is a common error for subscription. Ask PM to check
you cannot open ticket using the proper Chatbot at this time, so you will need to message PM here
