07-30-2023 11:45 PM
Good day,
Out by Drayton Valley Alberta we have been dropping calls, not receiving calls off and on for the past month.
Things that I have tried:
Reset iPhone
powered off and on
removed and reinstalled sim card
purchased new phone
tried a booster
cycled airplane mode
This has been happening with 2 public mobile phones.
Has there been any changes to Public Mobile/Telus towers north of Drayton Valley?
I understand that unfortunately Public Mobile doesn’t have WIFI Callings options. We are getting pretty discouraged.
Please advise on a course of action.
Thanks
08-02-2023 01:02 AM
Yes I had to creat a new Community ID.
thanks
08-02-2023 01:01 AM
Thanks for the response. I have been with Public for over a year and it seems this issue is relatively new. I will contact the CS_Agent. Thanks
08-02-2023 12:58 AM
I have tried 3G and LTE. It’s an IPhone 8. Can’t see anywhere that indicates it’s VoLTE. Thanks
08-02-2023 12:56 AM
Thanks, it is dropping calls in 3G and LTE for cellular. Thanks for the reply
07-31-2023 09:26 AM
@Alberta1 - are you also @Alberta ?
I noticed your community ID is created yesterday. Does that mean you had a previous community ID but when tried to access it it said that the name was already in use? That happened to many members here (including myself). You can have your previous community ID recovered, if you submit a ticket with customers support and ask them to recover it for you.
07-31-2023 09:24 AM
@Alberta1 - you are the 2nd member I have read about this similar issue today, but different province. Good troubleshooting you did.
Were you new a month ago? Or did you have working services prior to that without issue, then this was an all of a sudden change?
Maybe try the SIM Card into another phone and see if the issue persists. If the issue keeps happening then ask CSA to look into your account or area of towers. FYI, we are not public mobile staff, we are customers like you here on the forum. Ways to contact Public Mobile Customer Support (CSA) below:
1-Normally Faster - use this link to: Get Help With Public Mobile Chatbot], also found in various places in Public webpages, OR
2-go to your ENVELOPE at the top right of your Community Account which is where your Inbox and Sent messages are. Select the orange/peach color box with the pencil inside it to start a new message.
Type CS_Agent in the SEND TO box. This will create a private message to Public Mobile Customer Support. (link is provided in #3 below as well).
3 -Use this link (same as #2) Private Message to Public Mobile Customer Support Agents (CSA)
07-31-2023 12:22 AM
did you try changing to 3G network for the network mode?
which iPhone model is that? do you know if the phone is already using VoLTE?
07-31-2023 12:22 AM
There seems to be a possible outage in Drayton Valley. Just confirm on the outage map where you live:
07-30-2023 11:55 PM
Try setting your preferred network to 3G and reboot.
