12-04-2019 08:21 AM - edited 01-05-2022 08:17 AM
Hello, I'm into my 3rd month of public mobile. It's going well my only issue I'm having is the issue of so many dropped calls when I'm in Michigan and the USA. I have the roaming and data pkg in canada and the USA. Is there a solution to this.
cheers
don
12-05-2019 05:55 AM
Thanks hairbag1. I'll try that
12-04-2019 12:19 PM
@mellondon wrote:Thanks for your reply. It must be an issue on the USA side. I know I'm roaming. It's with at&t when I cross over. I'll try the moderator
cheers
You may have to manually select either of AT&T or T-mobile...whichever works best where you're at.
12-04-2019 12:15 PM
cheers
12-04-2019 10:04 AM
The towers should be supported while in the US. It may be issues on the US side with their service. Once you leave the country your phone automatically connects to the us towers (this is why roaming happens).
You can ask the moderator if there is any tower issues or if they can trouble shoot for you
