07-11-2019 08:17 PM - edited 01-05-2022 08:17 AM
Hey folks,
I recently realized that for the first since joining Public Mobile, that I had run out of minutes. Finding the Self-Serve options online a little confusing, it me a bit of work to get to where I could purchase an upgrade (crossing my fingers it would be effective right away--it more-or-less was).
Having made my payment (today, July 11th), I checked my payment due date is August 9th, but under My Rewards, it says my next plan cycle starts July 15th. Is this a contradiction? I am wanting to
1) not lose rewards and 2) not pay in full for partial cycle.
Can someone help me understand my position here? Will I be getting what I want (as above in #1 and #2)?
Thanks
Payment
07-11-2019 10:46 PM - edited 07-11-2019 10:48 PM
@johnCa11 wrote:Hey folks,
Thanks
@johnCa11 Instead of a plan change you could have also purchased the 500 minute addon for $5.00 to hold you over. Addon minutes never expire until used up so they are perfect to use as a safety net.
As for the dates is it possible that the rewards date is still showing your old renewal date? If yes, I wouldn't worry about it should correct itself before your next renewal date.
07-11-2019 09:36 PM - edited 07-11-2019 09:37 PM
@johnCa11 wrote:Okay. So they _should_ be the _same_?
In some places, it should specify a date, but in others, it should show a date of the very next day. One is the last day that you have paid for, while the other is the first day that the next payment will cover. Ironically, the plan usually keeps working past midnight because there is a delay in the renewal process.
07-11-2019 09:21 PM
07-11-2019 09:16 PM - edited 07-11-2019 09:16 PM
@johnCa11 wrote:Thanks--this is very helpful.
Could I still ask for a little more clarification.
I still find it confusing that the payment due date differs from the plan cycle date. Are they supposed to differ--or is it just an "issue" as @RossN said, that will clear up in a bit? I'd be very grateful for any clarity here. It doesn't seem to covered in the Knowledge Base Self-Serve Account Management section.
Much appreciated.
There's a known site bug going around for a while that causes dates shown to be incorrect.
07-11-2019 09:13 PM
@johnCa11 t may be best to just explian your issue to them good luck!!
07-11-2019 09:11 PM
Great. Can I just paste a link to this thread somehow or do I start from scratch?
07-11-2019 09:09 PM
@johnCa11 you can contact a moderator to look into it for you, if there is an issue they will fix it for you click here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-11-2019 09:00 PM
Much appreciated.
07-11-2019 08:45 PM
Thanks. I hope they do. 🙂
07-11-2019 08:39 PM - edited 07-11-2019 08:40 PM
Thanks
You don't really have much of a choice. If you wish to change your plan and have it take effect now, the full amount will be due immediately. While you will get a full 30 days (or 90 days depending on plan chosen) of the new plan, anything you paid for the first plan will be forfeited. The remaining 4 days will be lost from the old plan.
As for rewards, you won't lose anything. However, the reward amount won't get applied to your new plan's first payment. Those get added to your account balance after the plan change takes effect. On the renewal after that, you will have extra reward to reduce your required payment.
07-11-2019 08:33 PM
@johnCa11 hi those dates will clear up there seems to be alot of account issues today
07-11-2019 08:20 PM
The payment date is supposed to automatically adjust when your previous cycle ends.
