new subscriptions
Ggk
Hello community,
does anyone know, how often PM update new plan in to your change subscription sections
purpose of asking this question, so I check accordingly to change/upgrade my plan
please advise,
Thanks
8 REPLIES 8
hi @Ggk yes, that is the good thing with PM.  And the easiest and quickest way to get reward points is to bring friends into PM, 1 point per cycle for each friend as long as they stay here
Ggk
Hello community,
I would like to say "thank you to PM Team" , I feel great after using my Rewards to lower my bill,
GGK:)
Ggk
good morning,
thanks for sharing
@Ggk  wow I think they Listen 👂 to you , “LOOK” I just got text offer for special rate plan , so “yeah” public mobile has its bases covered 😎!!
Ggk
thanks for the support
@Ggk  That’s great idea you can message support to let them know about such a great idea 💡 and hopefully they will implement it
Ggk
thanks for the information, but if PM can send us a text or notification for new available plans, that would be really appreciate,
thanks again
@Ggk  There’s no set time to when plans change can happen randomly at anytime , currently though it shows some plans online set to expire after today so definitely check again tomorrow after lunch and I suspect there will be some new offerings , but really it’s good to check every other day as things can change at a moments notice and good plans come and go all the time . Just when you do finally see plan you like better be sure to use the change in renewal option and not immediately to avoid losing money on your current cycle
