04-23-2022 11:10 AM - last edited on 06-01-2022 11:56 PM by computergeek541
Dropped calls started a few months ago & has got progressively worse. I always used speaker & last week someone said try not using that. Now it is worse - calls drop or I can hear them & they can't hear me. I have the latest Apple, I've dealt with Apple doing analytics, they said it was the provider. I've tried all the tricks on-line & checked the SIM card. I live in mid town TO. I have 2 bars most of the time. So is my only choice to change providers??
04-23-2022 01:26 PM
04-23-2022 01:19 PM
THX - will try
04-23-2022 12:47 PM
HI @Anastasia888 Generally speaking, Telus should have strong coverage in GTA, but of course, different area could have a location specific problem.
Check if your friends and neighbors on Telus/Koodo/Bell/Virgin (they share the same network towers) to see if they have the same issue in the area where you have the problem.
Since it has been a few months and getting worse, open a ticket with PM Support and make them aware and investigate: At https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
04-23-2022 12:35 PM
Sorry i can't answer that question - COVID has limited my mobility - i live mid town TO
04-23-2022 12:31 PM
HI @Anastasia888 does it act the same everywhere? If you try in different part of the town/city, you get similar result?
Which city you are at?
04-23-2022 12:28 PM
iPhone 13 & worked w Apple yesterday & they said it wasn't the phone - it was the provider
04-23-2022 12:21 PM
@Anastasia888 wrote:well did a test - at 4 bars - call dropped after 35 minutes which is a BIG improvement but not good enough
HI @Anastasia888 What kind of phone do you have? Android or iPhone? Make and model?
04-23-2022 12:17 PM
04-23-2022 12:06 PM
How long have you been with PM was it working perfectly until a few months ago with no changes at all
04-23-2022 11:32 AM
have set 3G setting - thx - I'll try this.
04-23-2022 11:23 AM
lived on this ravine for years
04-23-2022 11:23 AM
did this NP
04-23-2022 11:18 AM
Do you experience call drops at particular location or it happens everywhere?
Could be some new development around you, tall buildings, cranes, etc.?
It could be closes cell tower is having issues and Telus is not aware of it?
04-23-2022 11:16 AM
Does your phone do this in different locations too?
Is it possible to try your sim in another unlocked phone to rule out a phone problem vs account?
04-23-2022 11:12 AM - edited 04-23-2022 11:14 AM
You can try manually switching network to 3G to see if there's any improvement in call reliability.
Otherwise, contact customer support agents to have them reprovision your account/SIM - sometimes that will help.
There are 2 ways to reach CSA's:
You’ll see their reply in your Community private mailbox in the envelope to the left of your avatar.
