Drop phone calls
09-27-2019 06:43 PM - edited 01-05-2022 09:20 AM
Can someone help me ? I’ve been with Piblic mobile since 2018. . This yr ( don’t remember exactly when it started ) but my phone started dropping my calls after 1 hr ( have anytime unlimited calling ) now past few days it’s been dropping calls within 5 mins of talking . My acct is up to date , I’ve taken SIM card out and still no resolution. I found APN settings there is digits in there .I don’t know if correct and can’t find Public mobile APN numbers . Please help or I’m going to have to go with another carrier as my cell is only phone I have for home and on road . Thankyou for your time
Service
09-27-2019 08:24 PM
@Dunkman FYI: to be clear, APN settings have no impact on calling.
09-27-2019 07:32 PM
09-27-2019 06:59 PM
@Cao wrote:I’ve tried several times chatting with Simon, can’t understand what I want no matter how I word it so have gotten no where’s with Simon Thankyou
It will take a bit longer, but you can contact moderator via private message:
Send a private message to moderator through the following link :
09-27-2019 06:58 PM
09-27-2019 06:56 PM
APN setting more important for data, not calling.
Here is the website:
https://apn-canada.gishan.net/en/apn/public-mobile
Here is the settings:
APN: sp.mb.com
APN Type: default,mms,supl *
MMS/MMSC Proxy: 74.49.0.18
MMS/MMSC Port: 80
MCC: 302
MNC: 220
APN Protocol: IPv4
APN Roaming Protocol: IPv4
... leave all other fields blank/empty
09-27-2019 06:55 PM
@CaoClick on the ? on the lower right hand corner. Chat with SIMon, once you think it understands you, type submit ticket for a support ticket to be sent to the Moderators.
09-27-2019 06:54 PM
How do I get in touch with a Moderator pls ?
09-27-2019 06:53 PM
@Cao wrote:My son also is with PM and is having same problem with drop calls .
Is it location specific? home, work, etc....
There was a significant issue with drop calls a few months ago, which required PM to "fix" things.
Might want to contact moderator as described above.
09-27-2019 06:53 PM
The chat thing last nite suggested taking sim card out ( which I did ) and to check APN settings .. I know where they are but have no idea if # s in there are correct or not as I don’t know nor know where to find correct settings . Do you have APN number setting so I can see if they match with what’s in my phone ..Thankyou
09-27-2019 06:49 PM
09-27-2019 06:46 PM
Maybe try your SIM in another phone to help determine whether it is hardware issue versus PM service issue.
If PM service issue, there have been some reports about drop phone calls. You may need to contact moderator to investigate. Click on quesiton mark on right lower corner of website and start ticketing process.
