12-05-2022 07:43 PM
Can someone please assist me with the following.
I will be driving through the USA crossing at Montreal, PQ and crossing back to Canada at Houlton, ME tomorrow and returning the same way this Sunday. My current plan consists of the following.
Unlimited Canada - wide talk
Unlimited International text
On the add-on usage side it says the following Add-On Usage12-06-2022 08:06 AM
PM calls roaming in US very poor. You may try SMS, or local sim.
12-05-2022 09:04 PM
HI @3101fries if you are going to get roaming, make sure you save offline map on Google map first, just in case you lost the conneciton
while data roaming is ok, I would suggest to get local prepaid US data instead. it is more reliable and in case you have trouble, you can likely find a kiosk of that company and ask for support
12-05-2022 09:00 PM
If you must do live directions and traffic then yes you'd want some data for all those live updates. But Google Maps lets you download large areas and then you can refer to the map offline. With the GPS radio (location services) button on, it will show your location on that offline map. You can zoom in however close you like.
Talk is the crux of the problem. Text and data should be fine as long as you have T-Mobile cell coverage. T-Mobile offers their old 2G network for talk roaming. But coverage could easily be yet more limited.
12-05-2022 08:38 PM
Thats a good question. Published data suggests that for Google Maps you would use 0.7 MB of data every 10 miles and about the same data every 20 minutes. If you are averaging 100 Km/h (on the high side and without stops!) you would use just over 6 MB per hour. With 500 MB you could drive for nearly 80 hours and travel 8000 km... much more than you are intending to travel. I've never considered this before but it's useful to know. Hope this helps.
12-05-2022 07:58 PM
Thanks
12-05-2022 07:57 PM - edited 12-05-2022 07:59 PM
Yes, those should do the trick!
Just make sure that while in the USA, you turn on the roaming in your phone and choose T-Mobile as the network of choice.
12-05-2022 07:54 PM
Thanks for the assistance,
So would the $15. US Roaming - Talk Text (10-day)
and the
$15. US Roaming - 500 MB Data (10-day)
Be all I require.
12-05-2022 07:49 PM - edited 12-05-2022 07:53 PM
Sorry but none of your add ons, data and calling minutes won't work in the USA.
You'll have to buy a USA add on, for text, calls and data if that's what you'll need.
