Double charge payment
Dran15
Can i get a refund on my payment yesterday i did change my subcription and when i check my bank account i got a double charge on my subcription
Chalupa_Batman
Hey @Dran15
If you use Change Now option instead of Change on Renewal, then that is normal PM charged you immediately to start the new plan.  Public Mobile is prepaid and may not provide refund, but they may help if you make an honest mistake.
Please create a ticket.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
@Dran15  If you didn’t use the chage on renewal option then that would be why . If you didn’t use the charge on renewal option check credit card . Is one charge just pending ? If so it should fall off . If both charges are posted and the difference isn’t sitting in your available funds then submit ticket
send  a  private message   To CS_Agent
hi @Dran15 did you use Change Now option  instead of Change on Renewal? if so, that is normal PM charged you immediately to start the new plan.
PM is prepaid and might not provide refund, but they will usually help if you make that mistake on first day of the new cycle.   please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
