Don’t receive phone calls
Diegopup
Unable to receive phone calls unless from a public mobile customer.  Please help!
Claudieln
Hello! I’m facing the same issue as above, can you share the porting sort number with me I need to fix this issue asap.
Tazzmanz0410
I am having so.e problem and I switched almost three weeks ago I can't recieve text message for verification of my device to complete public community profile either pls help
Diegopup
You are correct can you send me the number or link
hi @Diegopup if I am correct, you just setup a new account and just ported in your number??
if it is true, thr porting was not done.   there is a porting sort team you can call and check the porting status .  I will send you the number to your Community inbox. Please check
