07-28-2023 06:55 PM
Does this phone UMIDIGI G1 Max phone works with public mobile network?
07-28-2023 07:25 PM
The phone will work fine for talk/text/data on UMTS/HSPA (3G). It will work fine for text/data on LTE (4G). The phone would probably work for volte but this place has severely restricted which devices can be enabled for volte and your phone is not yet known to work.
07-28-2023 07:15 PM
I was on thies website and it says
Supported network bands
4G
FDD-LTE: B1 /2 /3 /4 /5 /7 /8 /12 /17 /20 /28A /28B
TDD-LTE: B38 /40 /41
07-28-2023 07:08 PM
07-28-2023 07:06 PM
Thanks for the reply. If I buy this phone on amazon and if it does not work with public mobile network?
07-28-2023 07:05 PM
I can't find the spec from the site, but look like these are the bands they have, BOLD are compatible bands
Standard UMTS. 850 900 1700 1900 2100
Standard LTE. FDD LTE: 2600, 2100, 1900, 1800, 1700, 900, 850, 800, 700
and these are what needed for PM
3G: 2/5 (850/1900)
4G: 2/4/5/7/12/13/17/29/39/66 (700/850/1700/1900/2100/2300/2600)
From these spec, it looks like it will work here
07-28-2023 06:59 PM - edited 07-28-2023 07:02 PM
